Taking apart a hydroboost???
RnrdTheFox
Superior, CO
I bought this unit off Ebay for $20. Its a F350 Super Duty HB. Upon inspection and wipping it down, I noticed that the sleeve that the push rod fits into, is cracked. I think what happend is the box got turned on its end during shipping and the push rod was jammed causing it to crack the sleeve. At least that's what it looks like. I could have been shipped that way too I guess. At any rate, it looks to be a good clean unit otherwise, and I only have $20 in it. It would cost almost that to ship it back.
Does anyone know what it takes to pull it apart and fixt the cracked sleeve? Think it will be expensive to fix?
TOFIC
Bronco Wrencher and Fixer
Redcliff Alberta
TOFIC here
Had a look at your unit. Nice crack but - - -
Knowing that that rod is sitting in a socket, that the socket is swagged onto the rod, taking it apart will probably break the piece and the piece takes a linear force (in and out) rather than a shear force (side to side or up and down) here is what I would do IF I HAD THAT UNIT.
Squeeze the crack closed ensuring the rod can move around in what I would think would be its normal planes of operation.
Put a tack weld on the crack to make sure it doesn't spread any farther.
Make sure rod moves in its proper planes
Use it keeping an eye on the rod for the first year. after that dont worry about it.
BUT this is me, not you, I can only give you my opinion!!
TOFIC
broncow72
Village Idiot
Spring,TX.
I agree with TOFIC completely. I don't know if you had it installed yet, but I would do just as mentioned above and be sure it has free movement when installed. If there is any binding.... make adjustments. Typically this will have a heavier downward angle when installed. I would think a couple washers on the lower mounting bolts would take care of that issue. Then fill the gap with some good RTV.
Any corrections oh great TOFIC? :-*
RnrdTheFox
RnrdTheFox
Superior, CO
TOFIC said:
TOFIC here
TOFIC
Thanks TOFIC. That's actually what I was think about and had the welder in my hand, but decided to do some investigation first. It just makes me nervous fixing something like that. Welding it "should" do the job, but you just never know what happens during a panic stop.... Nice part is that the crack isn't down to the area that the rod seats itself in the joint of the sleeve.
RnrdTheFox
RnrdTheFox
Superior, CO
Ok, I did a spot weld on it. I don't think it got very hot. I'll probably run with it until I come across another good deal (sooner than later I hope). At least I can get this one mounted and fab'ed in with everything and the breaks working etc.... I WILL be keeping a close eye on it. Thanks for the advice.
TOFIC
Redcliff Alberta
None at all! Good idea about the RTV and adjusting the booster angles.
Some of you guys are really getting good at this Hydroboost thing!!
TOFIC
