Third member yoke?
mp
Austin, TX
Does the standard third member yoke have a specific nomenclature or number? Is there a better or heavier duty yoke?
I am looking at purchasing a custom built third member, and want to make sure it is right the first time and either a) bolts right up, or b) is an upgrade from stock.
Thanks.
broncnaz
the stock yoke is a 1310 series which is the smallest for the 9in. You can upgrade but you will need a driveshaft built to match. next step up is 1330 then 1350. Although there is a conversion ujoint 1310/1330 but I wouldnt use it unless you have to as it may not be easy to get replacements but if your willing to carry a spare you should be fine. All the bigger yokes will bolt on what ever third member you get.
Gummi Bear
I think you're asking if there is one available that is stronger than the stock cast steel, correct?
I've seen billet machined yokes in the past, but they were pretty much a one-off kind of custom deal. I'm not sure if anyone offers one commercially.
Your best bet might to be to tap into the drag racing world, and see what they have to offer. You could also start with a call up to Sunray, and see what they recommend. 817-594-9201
welndmn
Many people sell a Billet 1350 (1 ton) yoke. Check E-bay for deals, they cost about 100$.
after do that you need to change your slip yoke in the driveshaft to also fit a 1350 joint as well.
