First, my plans on an actual engine/transmission swap is about 3 years down the road, depending on how things go. However I am already planning out what I will need plus giving myself time to look for a good deal while I get the rest of the bronco ready to handle more power and torque.
I have been leaning towards the ZF transmission, and in my research came across someone who suggested I look at a 1995/96 F-250 or 350 to be the donor of both the engine (5.8L 351W) and transmission (ZF S5-47). The benefit being that everything you need is all right there in one vehicle (minus adapters and the fab work needed to bronco frame), including EFI.
I have no prior experiance in engine work outside of doing general tune ups of my 302. I plan on using the engine as a hobby rebuild project and learning tool. The transmission I will likely have a shop do the install at this point.
What are your thoughts on this? I really don't need much on specifics yet, but any comments on advantages/disadvantages, or suggested items to research would be appreciated.
