I have a 1977 with three on the tree. It shifts fine but will get stuck in third gear sometimes. When this happens I have to pull over and go under the hood and push the linkage up and down until it moves. After this it will shift again. The cycle repeats. I have sprayed WD-40 on all the external linkage but the problem has not stopped. Could this be a problem in the column? Where should I look?
Thanks,
Bhall75
Thanks,
Bhall75
