Nothing Special
- Nov 25, 2016
- 816
The throttle shaft bearings in my carb are a little sloppy and the idle speed changes significantly when I spray carb cleaner at the throttle shaft. So I was thinking I'd "just" ream it out and press bushings in. But, as usual, the word "just" doesn't really mean what you'd think it means.
The issue I'm running into is that the wall outside of the throttle shaft bearing is only about 0.100" thick. I found this kit that includes a 10.9 mm (0.429") reamer to press in 11 mm (.433") OD bushings. But that only leaves about 0.070" of aluminum outside of the bushings. That seems pretty thin to me. Is there a better way to go with this?
