The idle on my '72 has been getting progressively worse and I finally braved the oven I call a garage (AZ in the summer) to dig into it. It looks like the throttle shaft holes are pretty wallowed out. At first I thought my problem was the base plate not sealing, because a shot of carb cleaner near the base while running would kick up the idle speed. But with a bit more testing it looks like the leak is at the throttle shaft.
So has anyone had luck with the throttle shaft bushings? Seems pretty straight forward; drill out the shaft holes then press in the bushings. But I'm a little concerned with getting them in perfectly straight. Also, is this a long term fix or just a short term band-aid?
Thanks!
Thanks!
