Tom's Twin Stick???
Colo77Bronco
Colorado Springs
I am installing the twin stick with my AOD this week and the adapter moves the shifter about a half inch toward the driver so I am wondering if it is going to be hitting my leg. Anyone have any problems?
Tgure
Phoenix
My Tom's twin stick on my AOD did not interfere with my leg that I remember. I have since taken everything apart so cannot go out and re-enact the scenario. If it does interfere you could simply put a bit of a bend in each stick towards the passenger side. ;D
Broncoholics
Windsor, CO
If its an issue, you can always heat up the arms and bend them to clear. My Atlas shifters sit pretty close to my right leg, but don't hit. I run an NV4500, so I would suspect it to be very similar is length to the AOD.
