Toploader installation question?
peterinman
East Jordan, MI
I installed my motor last night with a rebuilt toploader attached to it. I made all of my floor cutting and think that I have everything mounted correctly. However; the kit that I baught was used from a member here and shifting railse do not seem to be long enough. Could some people show me their shift rail configurations, and any advice on running them through the tunnel. I also had to cut into the support member on the underside of the tunnel. I was under the impresstion that I wouldn't have needed to do this for this tranny swap? Any advice would be appreciated.
SteveL
Huge chevy guy
Hawthorne ca
when I put the 4 spd in our 66 without a body lift it was really tight to get it in. I think I had to do some minor mods with the BFH. I used a duffy shifter for it. If someone else doesn't get you some pics of the linkage, I could take some. It just take me a while to get pics up.
Madgyver
Bronco Madman
Not yet installed but here is a pic of mine.
broncnaz
You shouldnt have had to cut any crossmembers to fit the 4 sp in. its the same size as the 3 speed The only cutting would be the hole needed for the shifter which I dont believe was even close to a crossmember on mine. but I guess the brand of shifter may make a differance mine was advanced adapters. unless your body mounts are shot or you have a 6 cyl adapter
peterinman
peterinman
East Jordan, MI
Madgyver, that is a perfect picture for what I am looking for. Thanks.
From what I can see I have different shifting ears and the PO of the kit tried to set his rods up different so the rods are "highly modified", if you know what I mean. Do you guys think that James Duff would sell me just the shifting rods and the ears? If not, do you guys have any suggestions on how I can get them?
Madgyver
Bronco Madman
Dan Williams Toploader Transmissions
Ask for Dan, He may have the parts you need.
Dan is a great guy, As I was doing my conversion he asked if I were going to use the original shaft and tailhousing, I had no use for them so he bought them from me.
