Transfer case Help needed
jaxfirebonco
Okay, rookie mistake number one. I pulled the body off and want to work on the transfer case and tranny. I understand about the special tool to insert to keep the pin bearings from falling out. My problem is I didn't put it into first gear prior to taking everything off. So how can I tell when it's in first gear? What position should the linkages be in?
I'm taking pictures and will post soon to show progress.
70_Steve
Old Guy
jaxfirebonco said:
Thank you very much!! I assume there is no need to mess with the front shifter?
Just make sure it's in neutral, or you won't be able to get the 1st/rev into 1st.
