Id definetly double check the heads I did see some 61 cc heads that had raised ports but they are not refered to as high port heads at least not in there marketed name. Ive got the standard Twisted wedge heads on my 302 and really like them. Get as much info about the heads as you can from the seller about any work done to them. Sometimes people screw up good things then offload it to someone else. So im always wary about heads that have been ported or otherwise modified especailly when they are pretty good right out of the box.
