Broncofan76
I was hoping you guys might have some insight into an issue. I have a rough idle at higher temps and only when stopped at stop lights etc. It also is hard to start when warm. It runs great at speed (around town anyway 15-40mph) but once I sit at a light for a few seconds it starts to run rough and if I don't put a foot on the gas and brake at once it will choke out completely and be difficult to start. I attributed my issues to various vacuum leaks that I have now fixed but still having some trouble although it running much better now. Last symptom for now is that it occasionally sputters and wont shut down completely when I turn the key off (ignition advanced too much?)
Some info on the truck:
rebuilt 302, cam, new performer intake/gaskets, new edelbrok1403 carb, no vacuum leaks, trans modulator and ignition advance hooked up correctly, hydroboost brakes, 180 degree thermostat that seems to pop at 180 as it should, truck runs a little on the warm side due to an undersized radiator but never gets over 220 - have replacement on hand but no time yet. I think the problems start around 200-210 degrees but can test some more if this is important.
Any help would be appreciated. And thanks to Phred for the help so far.
