Two Birds With One Stone?
Kaw-Liga
Palm Coast, FL
So a few weekends from now I will be removing my radiator to have it re-built and while it is out will be upgrading my tired stock p/s pump with a saginaw unit. My question is: should I, while the radiator is out replace the water pump? Nothing is wrong with it(that I can tell) temp is steady at 190 degrees, but I guess I just thought that having a new one in there would make me feel better. If I do replace it at the same time I think I would go with a new pump from my local NAPA ~50$ Now, of course I don't WANT to spend more money than I have to, but is that FlowKooler pump that WH sells really a whole lot better, like 40-50$ better? What do you think: replace the pump yes/no?; if so NAPA(original equipment) pump/FlowKooler pump? Thanks for the opinions.
Rob
mkaenel
La Costa, CA
I have a flow cooler and it is really hard to tell the difference (stock temp gauge never worked) over the last one (stock... I think) I had.
If you have a built engine and or live in a hot area it wouldn't hurt to run the flo cooler.
my .02
Steve
Grand Junction, CO
I wouldn't replace the pump unless it's leaking or there's a problem. It's easy enough on EB's to pull it out and replace the water pump when it does need it. I'd put a good name brand one on (like NAPA) and not the flowcooler pump.
My $.02
meckanik
Issaquah, WA
If the water pump is the same age as the PS pump it might not be a bad idea. Napa new (not rebuilt) is the way to go. Keep in mind this might also lead to replacement of the belts, hoses and thermostat while you're in there (just warning ya).
-Jeff
tasker
all knowing of nothing
NH
we deal with NAPA everyday at the dealership i work for. Never a problem if it does fail, good for a year. That being said, i wouldn't replace unless it was leaking.
broncnaz
I would wait water pumps are easy to change. You could check the shaft for play doubt it has any as the seals usually start leaking when there's play.
