Hi,
I have a oiler cooler set-up that I doubt I will ever use. I received it from the previous owner with the '70 Bronco.
The parts are new from what I can tell, although the cooler is not in the original packaging.
The set consists of a cooler with electric fan. There are two independent tubes through the cooler which would accommodate engine oil and power steering (or automatic transmission fluid).
A spin-on adapter for the oil filter is also included.
(The closest cooler I could find on-line is this: http://www.ebay.com/itm/Derale-Fluid-Coolers-with-Fan-15230-/331015621344 . It may not have the same specs, though.)
Please let me know if you have any questions, and I'll answer what I can. Hopefully the pictures will help.
Jeff
Jeff
