This UNCUT '66 has a U13 VIN, but has been upgraded to several '76 parts over it's history.
ENGINE: Fresh Rebuild on a '68 200 cu. in. Six. Less than 2000 miles. Engine is bored, new pistons, rings and bearings, cam and lifters, complete head rebuild. New timing chain and gears, new oil pump, fuel pump and Alternator.
Also has Pertronix module in the distributor - no points.
CHASSIS: '76 D44 Front axle - 3.54 gears - w/Disc brakes and Steering linkage. J-Pattern Transfer case. Smooth Shifting Column shift 3 spd. New Clutch and Pressure Plate. 3.55 Rear with Big Brakes.
INTERIOR: Rubber Mats, No Radio, Good heater with new duct and seals.
'76 Seats front and bench back with new upholstery. Inside tire mount with cover. Original Jack. Fuel guage works - other guages are under the dash.
EXTERIOR: Very solid Bronco to start. New steel in Floor pans, new rockers, new Dennis Carpenter Tailgate. All new rubber. Rear windows are tinted.
Stock Bronco wheels with new tires.
Contact Richard for additional info. & pics. 901-233-4733 or
ddmorris32@comcast.net
