under dash wiring Q
70_Steve
Old Guy
297, that Black/Green wire is definitely not a ground. It "originates" at the ignition switch as the Accessory Power wire. It's hot in ACC or ON and, among other things, powers the fuse panel for those fuses that are hot with the key ON. That 297 wire shows up in several of the 73-74 wiring diagrams, as well as diagrams for all the other years.
Baja71
Curious as to why you would install a 40 yr old wiring harness...?
tk1218
tk1218
Flower Mound
So 297 goes on the screw on the back of the ignition switch.
I'm on a budget and the harness appears to be in great shape.
jmangi62
I ripped out every piece of wire in my 70,I just don't trust any of it,starting fresh with a Centech kit from Wild Horses,good luck,Jim :cool:
thesnake
Jim, hope you kept some of the connections, you'll need them.
John
tk1218
tk1218
Flower Mound
1 other question. I do not have an aftermarket tach so I am wondering, do I just run the negative from the coil to the main ground for the engine?
Thanks.
