I am converting my 66 from Vacuum to Electric wipers. I have a complete setup of stock electric wipers. I have read that the vacuum wiper holes are smaller and further apart. Most I have read, have used the stock driver side hole, enlarged it, and then drilled a new hole for the passenger side. Some have talked about using the stock hole locations, enlarge the holes, and then cut and lengthen the rod in the mechanism. But I have heard that doing this leaves a gap between where the blades clean the windshield. Here are my questions.
1. What is the actual measurement for the distance between the holes for a stock electric wiper set-up?
2. If I use the stock holes, enlarge them ( also, what size does it need to be ) and lengthen the rod, will I still get the gap between the blade strokes if I going to install the Cherokee wiper upgrade?
3. And while I am on the subject, what wiper switch, with the ability for delay action, is the one everyone recommends? Is there a good donor in the pull a parts, or is there one from the vendors?
Thanks,
Scott
Thanks,
Scott
