does someone or could a vendor step up and start selling a stainless window frame kit that is removable (like roadster doors) to the early ebs? now that would be kewl.
Ben
well even if it was just removable, to put up in the garage/shop it would be sweet! or you could go a step farther and make it electric re-tractable down into the door....maybe after the electric window was let down... just some thoughts!
I'll check out WH and see what all is there.
thanks
Ben
thanks
Ben
SS can be painted. You sand it with 320 on a da then use a red scuff pad on it. Then you etch it, let flash off, seal it then paint. Instead of sealer you could use primer but you would have to sand your primer. With sealer you just start painting it after it flashes off.
