Vin Stamp Location
SCRAPPER
I Just Bought My First Bronco. Could Anyone Tell Me Where The Vin Number Is Located That Is Stamped Into The Frame? The Rating Plate Is On The Inside Panel Of The Glove Box, But Can't Find The Frame Stamp.
4x4Alaska
Wasilla, Alaska
TexasBronco said:
I may be wrong but I thought it was on the top side of the passenger frame rail.
that's where it is.....don't know if you'll actually be able to see it though ;D I found mine when I cut out the pass floor pan...
mtkawboy
Billings Mt
I never have found mine, it must be under the floor too. Ive wire brushed every inch that I can get to looking for it
4x4Alaska
Wasilla, Alaska
You may be able to see it if you have one of those mirror on a stick tools...there's not much room to work on top of the frame rail if you don't have a BL...it's right under the pass floor area...
iwlbcnu
I just found 2, a 66 and a 76, this weekend, they were mid way between the shock mount and the body mount, and could be see by looking down just between the firewall and the rear of the inner fender. The 66 even had the rear corner of the inner fender trimmed just to clear the number.
