    Discuss it more here:
TN Wanted-rear axle shaft
Status
Not open for further replies.
byson1
Nashville
Need a good drivers side, small bearing, 28 spline rear axle shaft. Mine has a seal groove and I can't get it to stop leaking.
I'll be making a road trip through Indianapolis, Chicago, Minneapolis, and all points in between in a couple weeks if by chance you're in that area. Gladly pay for shipping too.
bronconut73
thought about a speedy sleeve seal saver?
Found one of those on a Buddies 8.8 in his FSB.
We were putting in a lunch box locker.
He didn't even know the Speedy Sleeve was there. Must have been put on prior to his receiving of the Bronco.
He put 77K on that Bronco with that Speedy Sleeve there without a single issue. We put that axle back in three years ago. Still fine.
So one more vote for the Speedy Sleeve.
Doesn't make much sense to invest too much in small bearing 28 spline axles.
byson1
byson1
Nashville
Searched high and low for one and can't find a part number. I've found them for the big bearing but not the small. Doesn't mean it's not available,
but I had no luck.
NicksTrix
Go to a place like napa and have them look one up by the od of your axle shaft rather than application
byson1
byson1
Nashville
Tried that too with no luck. I even check the speedi sleeve web site, downloaded their tech sheet
and they were not showing anything with the correct diameter.
Status
