I have stock 302 set-up thanks to living in California and having a '77 but I am moving to Colorado this month. I want to get a weiand stealth intake and 470cfm Holley truck avenger carb. Will they fit with my stock hood and 1" body lift???
With a 1" body lift you might be okay depending on your air cleaner. The truck avenger will be about the same height as a stock carb. I've attached a photo to use as a reference. On the left is the Stealth intake, on the right is an Edelbrock performer, which is about the same height as stock. It's about 1.5" taller than stock, maybe a little more. With a drop base air cleaner you should be okay.
I have not put my stealth under the hood yet, but the reason I bought it was that it has a waterjacket running across the back 2 ports. The performer does not. A little better cooling seemed worth it to me.
Maybe sbingham2 would lay a straight edge across the carb mounting surface on the new Stealth. Measure the distance from the carb mounting surface to the front gasket surface on the bottom of the manifold. Do the same with the stock manifold.
Get some modeling clay from WM or a toy shop and put on top of the existing air cleaner and close the hood. Measure the height of the mashed clay. If the difference in height between the stock or existing manifold and the Stealth is greater than the mashed clay you have a problem.
