weld thru primer?
mavereq
where the heck do i get this at? i checked at auto zone and a few other places and haven't found any yet.
siderbox
The stuff I have is made by 3M.
I got it from a automotive paint supply house.
trailpsycho
I haev used all of the above, but the u-pol. 3M is the best, but it was $10-12/can. The ACE hardware version is OK (price ws ~$6-7). The NAPA (Williams-Seynor--or something like) is OK as well and was also reasonably priced. If you are only going to be doing a few small important projects, go with the 3M. IF you are going to be doing alot of work, then go with one of the cheaper ones. I do remember the 3M going a long way, moreso than the others.
Good luck.
Mark
Bronco Klutz
NW Indiana
At Napa tell counterboy that you want Napa part # 7221
Cold Galvanizing compound - weld through primer
You can find it online at www.napaonline.com
type in the part number in the search
BroncoJAK
Never liked the 3m weld thru. Seems you have to burn through it before you can weld. Like purposely adding a contaminant to your weld. Best I've ever used is Standox red/brown 1k primer. It's an etching primer but the zinc content is high enough that it works great as a weld through.
mavereq
mavereq
i'm only needing it for a few things. gonna weld on new upper coil brackets and f250 shock mounts this week and don't want to cover up any bare metal.
allenfahey
X2 At work we use the same stuff but it's Spies 3055 (i think that's the #)
When you use weld thru you don't want a whole lot of it on there. Don't go for coverage, you only want one light coat. I've seen bodymen pile it on till they get runs coming out from around the panels being welded. The tech sheet for the Spies says a light coat is all that's needed.
