West Coast Broncos Headlight Relay Harness
Dusty
Get brighter headlights with WCB's easy-to-install Headlight Relay Conversion Harness. This harness provides direct current to your headlights from the battery, rather than going through the dash switch and wiring harness. The result is brighter lights from your stock lamps, and more power for aftermarket lamps. This harness enables you to run both high and low beams when the high beam switch is engaged, or simply unplug the inline diode to return to normal function. Comes with installation instructions.
Priced at just $69.95 each. Click here to order yours!
bigmuddy
Marthasville Missouri
I don't have this one but I do run one and it makes one helluva a difference! It's and easy install by the way.
69.95 is a reasonable price too!
Duke Nukem
Simi Valley
I can vouch for that. I've got an RJM headlight relay harness and have to say that it was a great upgrade. Very easy to install and allows me to run H4 headlamps that are so much better than stock. This type of upgrade is worth every penny.
ObscureMachine
Seatbelt Orifice Officer
World Headquarters
I did my harness and h4 lights in about 30 minutes. Well, actually about an hour because of the talking to friends and having an adult malted beverage and trying to explain to some wives what H4 means.
