WH Racket Jacket
NorCalBronco
Has anybody used this stuff before? I've been trying to make my Bronco more comfortable/quiter for longer distance and I think something like this in theory seems perfect.
SC74
Haven't seen that before. The Rhino lining in my interior achieved the same purpose - helped deaden sound and reduced heat, but the Racket Jacket material is much cheaper. You would have carpet over it I imagine to keep from tearing it up.
Bronco Brian
I have some of that stuff ( Not W/H ) in my Bronco for a long time now and it does help
blubuckaroo
Grease Monkey
Ridgefield WA
I must sound like a broken record but bed liner coating isn't for everyone. It looks like goober, doesnt insulate from sound or heat very well and is permanent! It really depends on your application. If your interrior gets wet a lot then OK. But if you usually keep the top on a good rust inhibitor paint, insulation then vinyl from Custom Carpets works really good. Insulate under the side panels, in the doors, and under the head liner and you won't believe how quiet these can be. Makes my tunes sound really good! Consider everything before you put that stuff on. A lot of guys are using it just because it's an easy way to get a uniform looking interrior. Also if it isn't perfectly bonded everywhere you'll still get rust.
NorCalBronco
NorCalBronco
Awesome, sounds like a good deal. My tub is already linexed so I wouldnt worry about rust, and I plan on having the top on for a long time( just got it back on after like 4 years :) ). Bronco Brian, what product do you have on yours?
blubuckaroo
Grease Monkey
Ridgefield WA
Tom's sells a thermal blanket I used on the floor but added a complete floor insulation from Custom Carpets too that was kinda like thick carpet padding. I had them send out lots of that to insulate the roof and side panels. If I could just get some dual glazed windows like on a house I'd have the "cone of silence"!
blubuckaroo
Grease Monkey
Ridgefield WA
I just looked at the WH catalog and really like that stuff. Looks like what I used but has all the side & door panel parts available too.
And don't buy into the "spray on liner does the same thing" comments. Been there and it won't! I just hate it when my feet get hot.:mad:
