Mid '80s to mid '90s E series, F series and Broncos have the externally frame mounted pump. For the price, just grab the whole pump/ bracket! Use your new pump in it and keep the used job as a trail spare.;D
You can use a factory bracket and do a little work on it to mount it different ways. This is a factory bracket and about 5-10 minutes of re-bending to mount how I wanted. The other leg comes down on the other side of the frame.
the es2000 pump and the bosch pumps are different diameters, on my Bronco with the Ford mount I have a mounting plate for drilled so the stock ford mount can install both pumps, I think some of the pumps come with a larger foam sleeve to make up the diameter difference, but i get a lot of my pumps used and they are missing at times.
