What Is The Switch Next To The Feul Selector Valave
edmond1744
los angeles
Hello,, I Am Planning To Take My Aux Tank Because I Have A Nwmp 23 G Feul Tank.. I Noticed There Is A Switch Next To The Feul Selector Valve,, What Is It? What The Purpose? My Question Is If I Take Out The Aux Tank, Then I Dont Need The Valve,, This Way I Can Have A Straight Feul Line To The Pump,, Will This Work? If It Did, What Do I Do To The Switch? Thx.
oh2bnok
Olathe, KS
Is it a toggle switch with a bezel around it, if so it probably is the stock switch someone moved next to the valve. Or it may have been for an electric pump on the aux tank, who knows, could be for the laser beam guns mounted under the bronco. Yes you can run the fuel line straight to the pump.
Gordys74
Southern Iowa
You can run it strait from the tank to the pump, but, Geeze, would'nt it be kinda nice to have a shut -off valve? If you need to replace the pump, you could shut off the fuel. Also helps with anti-theft to be able to shut off fuel to engine. Most amatures don't know about the valve.
I plan on using the valve when I change to a large fuel tank.
