Whats a good 3 1/2 lift for a uncut and a tire size?
grinder1717
Might even go a 2 1/2 lift. Need to fit the orginal 15 inch rim. Anything I need to change drivetrain wise for the best ride once the lift is on? Its a 77 Ranger, disc, auto trans. Thanks guys.
75 Ranger
Im partial to Wild Horses lifts. 3.5" lift with 31x10.50 tires. Nice stance and no drivetrain change.
MattW
Tom's 2.5" lift with WH's 1" body lift and 31 x 10.5 tires.
I've read that some people run into drive line issues with a straight 3.5" suspension lift and others say it's not a problem. I didn't feel like falling into the problem category so I opted for the 2.5" lift and the 1" body lift route. The WH's 1" body lift is a nice upgrade as well. The extra 1" helps a lot when you're working under the Bronco.
73stallion
Eugene, OR
33x10.50's with a 2.5" suspension and 1" body lift.
driveline depends on the bronco. i've done lifts on some and it was fine, others i've done lift and the driveshaft wouldn't even extend enough to reach the yokes. did a 2.5" lift not too log ago, the slip yoke maxed out and it was 1.5" away from the yoke.
Adarcy
x2 on the Wild Horses Suspension Lifts.
3 1/2" w 31x10.50's
Adarcy
Zillacon,
What dealership is your wife's from? I can see the badge on it, but can't make it out.
Adarcy
Ours may have come from the same dealer ;)
Pflyboy
Brighton, Colorado
Zillacon, my bud said he saw two Broncos off of 136th and I-25 last Saturday around 10am. He said they were the cleanest Broncos he ever saw. His description matches your pics :cool:
Zillacon
Hackin Away!
That was my wife and I coming back from the monthly Bronco Breakfast. Both Broncos were originally bought in Colorado, the yellow one in Denver and the Red one from Pueblo.
MattW
Zillacon, those are both very nice Broncos! Did you buy them that way (original owner maybe?) or restore them yourself? Either way, they are both inspirational to me and my rust bucket!
Zillacon
Hackin Away!
The yellow one we buffed out as it was sitting for a long arsh time in a barn with only 40,000 original miles and original paint. The red one had one re-paint and sat for 10 years in a garage. I have not touched the bodies or paint yet other than a good buff and wax. Just the drive train to make them both road worthy.
G
grinder1717
Holy cow, they all look super! Thanks to all for the quick info and pics. Its going to be a tough one! Thank fellas... Jim in Spokane,Wa
idhawkdriver
Boise, Idaho
Here's a couple of shots of mine too. :) 31 x 10.50's on stock rims. 3 1/2" leafs in the rear, with 4" coils in the front. Over Christmas I tried to get a little twisted action going to see if the tires would rub...no problems at all.
rootbeer
Well I just finished putting on a WH 2.5 suspension, the ride, handling, and look is awesome. I did have problems with the lift it's self- first there was the problem of not sending everything the first time. Then details left out of the instruction, got past that after the light bulb turned on. But over all I am impressed by the improvement it has made for the Bronco. The front springs are supporting a Protofab Rocksolid winch bumper and Mile Marker 9500 winch with no sag in the front. Now I need to put on the 1 inch body lift.
englewoodcowboy
Lick Creek Restorations
This is the first time I have seen this thread and I have to say Zillacon, you officially SUCK! I was soooo ready to cut my EB till I saw yours with the 33's..... GOD I keep making changes and need to stop but this one .... I think I will keep mine uncut now.... Thanks alot!...LOL
I dont know if this site is good or bad as I keep having ideas and picturing in my mind what it may look like then WHAM someone posts up what I was thinking about and it looks so much better than I anticipated and makes me change my mind again....
Adarcy
Let's see some pictures! That's a very similar setup to what I will be doing. I'm looking at the Hanson bumper w winch on my 70 that had a 3.5" lift.
Question: do you have the single or dual shock setup up front and are they the shocks that came w the lift?
1sicbronconut
Sounds a lot like my set up 1" body and a 2.5" suspension.
