What is the difference between the Ebay 8" brake booster kit for $180.00 and one from one of the Bronco vendors that range from $300.00 to $400.00? Is it worth it for a certain reason to buy from the vendor?
Nice! You won't regret that for sure. I did the disk upgrade 20 years ago and it's still the best upgrade I've done. I added the booster shortly after that. I happen to come across a used booster and bracket locally and just purchased a master for a '76 from Napa and called it a day. Still running these parts 20 years later.
People say Hydroboost is far superior and they are probably right. I'm sticking with the vacuum booster as it works fine for me with my 33's.
I've never bench tested one but imagine with a vacuum pump you could find out if it has a leak.... Mines been good for ever and that's being a stock unit so not sure how often they fail. I say install it and check if your idle goes up when connected (not good). Easy enough to swap a new one in if yours is bad.
