stingray427
- Mar 1, 2006
- 194
Quick question, will a 15" x 10" rim with a 3.650 backspace and a -47.00mm offset fit on a 77' with four wheel disc brakes?
Thanks.
Thanks.
Labbster said:It should. I have a 76 with rims with 4 inch backspacing. I had to put 1/4 spacers from BCbroncos on and they barely fit. So, if all else is equal, they should fit.
stingray427 said:Thanks for the reply, but I am a bit confused. You say a 4" backspace plus spacers barely fit, but these rims I am referring to have only a 3.65 inch backspace. Why will they fit or are you saying that I will need a spacer also?
Quick & Dirty said:Backspace is the distance from wheel mounting surface to the inside of the rim.
Yes, that is correct on backspacing. Offset I think is the distanc the mounting surface is from the center of the wheel. I.E. I think an 8" rim with 3 1/2" of backsapcing would have 1/2" of offset. Check one of the big wheel sites to verify on that one.msweb said:I just found this thread while looking for some help with the terminology, namely backspacing.
The distance would be measured from the inside of the wheel mounting surface to the inside of the rim, right?
****Edit - If that's right, what's offset?
Thanks, and please go easy on me for stupid questions ?:?
rcmbronc said:I have a 76 with 15x8 wheels with 3.75" backspacing. They worked great with no interference. I went tie-rod over with stonecrusher and added those 1/4" spacers from BC (the ones Saxman has shown) and it clears fine.
