jmhend
- Dec 25, 2007
- 2,742
I have been looking at several options for moving the bronco around in the driveway (asphalt) / garage (concrete). Current wheels are 15x8 with 235/75/15 tires but would possibly need to accommodate up to 37/12.5's
Trying to weed through reviews / pro's / con's and just thought I would ask the pros for thoughts and input on the links below.
Thanks.
Pentagon Tool | Commercial Grade 4-Pack | Tire Dolly - Tire Skates | 1,500 lbs Rating | Red : (https://www.amazon.com/Pentagon-Com...7668999&sprefix=wheel+doll,aps,305&sr=8-Pro's with these are cost.... Con's are you need to tote a jack around with you no matter what. 33&swrs=152CBF506086728E02320F58E170BE05)
Pro's no need for a jack.... Con's cost, limited tire size, and possibility of leaking fluid (same goes for the remainder of the links).
Eastwood Auto Moving Portable Wheel Dolly Hydraulic Foot Pump Hand Truck Heavy Duty Positioning Tire Lift 2 Piece Set (https://www.amazon.com/Eastwood-Mov...1587668932&sprefix=wheel+doll,aps,305&sr=8-19)
GoJak Model G4520 (https://www.amazon.com/GoJak-Model-...1587668932&sprefix=wheel+doll,aps,305&sr=8-15)
Thanks.
