eRandall38
Newbie
- Nov 3, 2018
- 16
I just replaced my neutral safety switch, and while down there I noticed a rod running up to the engine. I followed it and it leads right up to the driver side of the carb. I also noticed it was not attached.
I can't figure out where it is supposed to attach to the carb at, or how? You can see a photo of the loose lever and a red arrow where I am guessing I need to attach it to somehow?
https://ibb.co/BwM7vF8
When driving I noticed it is shifting down and up strangely, could this be the cause? Shifting up it seems to lag and reach higher RPMs before shifting. Shifting down it also lags and almost works as an engine brake. Both shifts (up and down) seem to be "harder" as opposed to "smooth".
Is it ok to drive while I work on getting the parts needed to fix?
