Where to get a good Suspension System...
Beaumont, Texas
I have been looking at suspension systems for a while now and the only ones I have really found go only up to 4.5". I need a lift somewhere around the 8" mark. Should I just go to a local lift shop and tell them what I want and just hope I get something good, or do any of you have any suggestions? I want something I can count on lasting with no problems.
HELP PLEASE!!!
BoltBuster
www.bcbroncos.com
Basic Kit 4.5
Includes B.C. Broncos 4.5" front coil springs, B.C. 4.5" 11-leaf rear springs, polyurethane bushing kit, drop pitman arm, adjustable trac bar, rear leaf shackle bushing kit, heavy duty U-bolts and extended stainless steel brake lines.
mxpaz
KC
I would say wildhorses or BCbroncos is your best bet. Are you wanting 8" susp lift? I would say 5.5 susp and 3 body is pretty tall.
SaddleUp
Vancouver, WA
HELP PLEASE!!!
I'm not aware of any complete suspension system that goes that high. The tallest complete system I am aware of is 5 1/2". You can use a body lift with it though to get 8 1/2". For more than this you need to assemble the components yourself. There are a few options. BC Broncos sells a 6 1/2" front spring which will get you a little closer. You could also get a 6" or 7" spring designed for a newer Bronco (78/79). Add 1 1/2" to these for the lift on an EB. (I.E. Net would be 7 1/2" and 8 1/2") You could also lower the upper coil mounts to gain the lift. Another option is to go to a coilover front suspension with custom mounts. In the back you could have springs built, use a combination of springs and blocks (Not a good option IMO), do a shackle flip (The only limitation with the flip is how long you can make a set of shackles, the longer they are the less stable it will be), or you could do a coil over 4 link suspension in the back. At any rate once you pass about the 4 1/2" mark you will add in a lot of work to get everything to work right (driveline angles etc.) and once you go higher than 5 1/2" you will need to start putting together your own stuff to make it work. I suspect that you will have problems finding a shop that will install anything higher than 5 1/2".
BTW, why do you want to have that much lift? You can get some pretty big tires under an EB with 5 1/2" of suspension and 3" of body lift. The only real limitation is how much of the body you cut out for larger flares.
SnwMnkys
Orem, Utah
I dont think anyone makes 8" lift coils. You could probably get Big Bronco or F150 lift coils and achieve 8" of lift. Why do you want 8" anyway? 5.5" is plenty big on these things. Also coils that tall would bow extremely bad.
Scott M
Baltimore
above posts are right on height.
i think 3.5 to 4" w/ cut fenders is perfect for 33", and OK w 35s.
BUT, STAY away from Rugged Trail. thats my .02. price was right and i tried it back in the 90s. sucks, but to be honest, i'm not even sure they are still in bizz.
BRussell
Winston Salem
I would call RICH at Wild Horses. I got my 5.5 suspension from him and I am extremely happpy with it. I have cut fenders ans I am running a 36x13.5 IROK (Bias). Whatever you decide get rear leaf packs.
Brad
texashcane
Argyle, TX
I'd spend the extra money on extended radius arms with a 5.5" lift. It definitely extends your suspension travel range.
Gummi Bear
Why do folks feel the need to go so tall on the suspension? Make friends with the sawzall.
I'm lowering mine an inch, I want a lower COG (I'm presently running 3-1/2" suspension and 2" BL) (I can also remove top and doors to reduce weight up high)
97XEB
As usual, and as I've quickly learned about this board, people really provide tons of fast, accurate and overall great advice. However, still no answer to the most important question which SaddleUp originally asked:
Why do you want that much lift?
What size tires do you plan to run? What type of wheelin' do you do? What part of the country?
I've seen picks and read posts from a ton of people here who run 3.5-4.5" suspension lifts, 2-3" body lifts, 36-38" tires and have just SICK amounts of full-range articulation. (In fact, I've read so many good things, and seen so many cool pics re: such combos that I'm going with Chuck's 4.5" springs, Cage's extended arms, Duff's 2" body lift and when my 35s wear down, 36" Radial SSRs or IROKs.)
Seems like that type of combo, and a sawzall for even bigger meats like 39-42s, like Gummi Bear suggested, (ok, maybe 42s are stretch??) and a good driver could handle anything, yet not stress the driveline angles too much or be too ridiculously high as to be completely unreliable and/or unsafe on the road. (But that's assuming you're building an all or dual purpose rig that will see street and trail time.)
My .02, whatever it's worth. Good luck with your decision and post pics when done.
