I've looked all over and I see a lot of guides for how to install a new head unit etc when there is ALREADY WIRING FOR AN EXISTING. What I can't find is how to do it without it.
I've got the manual, the repair book, wiring diagrams, etc
I'm just trying to find where to pull power from. I might give up on the head unit / amp / speakers combo and just do a simple roll bar mounted all in one speaker / bluetooth receiver unit (play from my phone). But I want it to be able to charge when I'm driving.
In modern cars to add an accessory I would find an empty fuse slot, but I don't think I have any on the bronco?
Idea One
Run new wire from the battery to a toggle switch on the dash (there is one not hooked up to anything, doesn't match spot on the dash diagram - it is where an optional cigar lighter should be, and it isn't hooked up to anything), so I could run the power wire from the battery to that, then turn it off when I want to so it doesn't drain the battery. Then I just run that wire straight to the speaker.
Idea Two
Have it run only off the alternator / when ignition is on. For this, can I split a wire that goes to something else with a low draw? Or do I need to find an 'empty' / unused supply / fuse?
Should I use the fuse box in the glove compt? I have a couple wires there that don't run to anything currently (cut and zip tied by previous owner I guess)...
If anyone has a thread link or youtube or anything to how someone else has done it happy to look at that, just can't find one without existing wiring!
Thanks y'all.
Idea One
Idea Two
Thanks y'all.
