- Aug 27, 2001
- 5,151
I am going to get a new lower steering shaft because the 2"body lift is to much . I 'd like some comments if possible on the Borgeson and the Flaming River lower shafts.Borgeson makes one that has a telescopic slip shaft that is a direct bolt on to your original rag joint. Make you shaft like 3" longer if you need it.
Flaming River has the 2 u-joint style with a u-joint on the steering box end and one where it meets the upper shaft.I think you have to cut the upper shaft to use this style. It is also telescoping. Which is better , stronger, safer, easier to install.
PLease let tme know. I am gonna order one tonight if I can.
Or if you have cut, tubed, or welded one..how safe is that? It would save me 200 bucks to cut it and tube it ,but I wanna be safe too.
Thanks Much,
Blue71
Thanks Much,
Blue71
