Wild child underseat storage box
bigmuddy
Marthasville Missouri
I know that Wild Child is out of business but is anyone making the underseat storage box? Too, can someone post pics or provide a link to the wild child storage box they are using.
Thanks Ben
Smokeater11
Auburndale,FL
Why not just make your own? That's what I did on both sides. The passengers side was easy. 1 piece of 14 gauge metal and 1 bend. Lay it in there and weld it in. $2.00 for a set of hinges and a scrap piece of metal makes you a door for it. Took me less than an hour to make mine for the passengers side. The drivers side was much more complex and time consuming. Here's the drivers side.
Smokeater11
Auburndale,FL
I don't have a specific pic of the passengers side but you can see it in this pic.
bigmuddy
bigmuddy
Thanks Gents for the help. Smokeater11, where did you get the slides and the drawer or did you build the drawer as well?
thanks Ben
phred
Earth
there's a detailed write up in the jan/feb or march/april 09 issue of bronco driver of the a wild child box install.
dnewman9
I would like one of these as well. Worst case I will get someone to bend up the steel. Should be 2 bends and I could bolt it to the floor.
I still would have to come up with the drawer but that would be the easy part.
If someone finds one let me know.
Dennis
Buldozer
Bronco Virtuoso
God's Country
Two words....plywood baby! I have one made of 5/8 plywood that works great. Does not slide and stays put!;D Now stop drumming up additional projects to work on or you will not be finished by OCBR Ben! ;)
bigmuddy
bigmuddy
No new project bulldozer, just trying to complete my list of repairs. I am still agonizing over the seat install! Got to have seats if I am to make OCBR at all with a bronco under me.
Ben
JWMcCrary
I have the one that Wildhorses sells. Nice to have a spot handy to put a few things, however any steep downhill and it all comes under the passengers feet. Some type of drawer/door would make it alot better.
Smokeater11
Auburndale,FL
Ben I built the drawer for the drivers side as well. I bought the sliders at Lowes for less than $5.00. I'll have to get you some pics of the passengers side tonight. I don't have a drawer on that side although that side would be much easier to make a drawer in. The body brace on the drivers side makes it a real PITA. I might not even be able to use the drawer on the drivers side depending on how I can manage to bolt the seat in. It's a real tight fit.
Smokeater11
Auburndale,FL
Smokeater.... dig the granade.
I have two grenades now!! My 8 ball broke so I put a baseball grenade in it's place. So now I have a baseball grenade on the gear banger shifter and a pineapple grenade on the t-case.
bigmuddy
bigmuddy
JWMcrary, did you mount your seats directly to the WH unit or to the rollbar?
Smokeater11, 10-4 on the build, send some pics when you get time ASAP.
I am digging the grenades too! very cool, kinda lends a rat rod vibe.
Ben
JWMcCrary
The rear is to the floor, the front is to the WH unit and the floor.
Smokeater11
Auburndale,FL
Here are a few pics I took tonight with my cell phone. It's a really simple mod. I used 14 guage instead of 16 because I knew the seat would be bolted directly to it, and I already had the metal. AND since you guys like my grenades I thought I'd add a pic that had both of them in it. I might have to take the clip and pin off the baseball one if it gets rough on my palm.
Steve83
Remember that the floor is what connects the seat to the seatbelts, the frame, & the cage. So if the seat rips out, or bends a smooth flat piece of sheet metal into a wave, it means someone's skull is going where it shouldn't. That's why the original floor isn't flat - not even the footwells. There's always a bend or corrugation to make it rigid so it doesn't warp.
So a flat deck over a drawer is probably too weak for a chair that needs to hold a 200-lb guy in a truck going over rocks, even under 5mph. It would have to be VERY thick, and even then, IDK how long it'd stay flat. Even a small channel creating a ridge near each seat mount would help a LOT. See the original ones in those pics above? See how thin the original floor is? It doesn't take much to do a LOT of good.
On Frank's, I went a different route. I built a box that supports a '78-89 passenger seat base so the chair flips up, and IS the lid for the box.
