- Feb 2, 2006
- 108
I'm getting to the point where I can install these rock rails: WH Rock Rails
They come pre-shaped kind of like your rocker panel. You push them up and fasten them directly to the rocker sheetmetal. However, the rocker is shaped a bit like this quick diagram I drew if you look at it from the front or the back of the vehicle:
When you hold up the rail, it lays against the rocker near the top of the curve under the door and just hits the seam that points straight down. This makes it so most of the slider isn't really touching anything? The instructions don't mention it but do people cut off the part that hangs down so the slider fits against the rocker better?
![rocker_panel_diagram - Selection.jpg rocker_panel_diagram - Selection.jpg](https://classicbroncos.com/forums/data/attachments/928/928793-c2f5ebc5a258dee0857e03704a19096a.jpg)
