Are the tie rods on the Wild Horses F-150 set bigger than those on my stock '77? Im running 16" positive offset wheels and the tie rods are inside the wheel. If they are bigger, they may not fit.
Are you going tie rod over? If it is staying under it should still fit on the 76-77, especially with the 16" rims. The TRO is when you start having issues and either need to run spacers, less BS, or bigger wheels.
I have the wildhorses 3 way, '76 knuckles out, and 16x7 rims with 4" backspacing. Mine fit fine and I at one point was thinking of going to f-150 TRE's since they are bigger but couldn't get a hold of a reamer in enough time. They would have fit though.
Am I guessing correctly that you have TRE's all for the f150? I think they are a taper with the widest at 7/8' instead of the earlier 3/4. Will you have to ream your knuckles to fit them?
For your case, you'd probably stick with under but a lot of guys that hit the trails a bit harder than average put them over so that there is better clearance and so that the drag link angle is lessened with bigger lifts. If you put it over there is less clearance than under between the tie rod and the wheel as the knuckle is above the centerline. The 76-77 knuckles if I remember correctly are pretty high especially when compared to the later D44 knuckles that people use for disc brake conversions.
