triggers68
I have a 1984 Ford F150 4x4 rolling chassis I bought several years for another project. Will the Auto Trans and t-case fit and work in my eb build without too much trouble? Im using the 302 from the 84' already.
You can make anything work with a torch and a welder! Seriously, You will be looking at crossmember issues, driveshaft issues and linkage issues. There might even be interference with the tansfer case hitting the narrower bronco frame. With the 84 engine going into an early bronco drivetrain, you will be looking at finding a flexplate with the 50oz wt that matches the earlier bolt pattern and tooth count( pre 80 302 engine are 28oz, post 80 are 50 oz harmonic balancer and flywhell/flexplate)
Your 84' engine uses a 50 oz balancer and flex plate, which are correct and don't need to be changed, especially if your using the trans, although I don't think it's an AOD like you want, it's probably a C6. If you want efi, I'd look into a 89-91 mustang intakes and mass air meter, and get the AOD from that also.
You can run the C6 with only limited problems associated with length.
