Windsheld Removal?
JohnJohn
Richmond
This may be a dumb question but how do you remove the windsheld frame on a 77?
It looks like I need to drill out the spot welds on the windsheld hing but if that is what it takes I am leaving it in place. I am doing a frame off and would like to pull it for some minor welding repair but can do it while it is on the truck.
wildbill
Old Bronco Guy
:p :p :p You got it drill all the spot welds and off it comes good luck and have fun.:D :D :D Bill %) :cool: ;D
rellimgneb
Reno, Nv
I was going to remove mine for my rebuild too, but when I saw how many spot welds to drill I decided against it. If you do remove it though you can just reattach it by bolting it down and then you would be able to take it off anytime you want.
JohnJohn
JohnJohn
Richmond
Thanks guys for the info.
I have the Crazy Horse build shows on my TVIO and Stacey says "just unbolt the windshield” just before he and some other guy pull it off of the Bronco.
I thought that maybe some years had bolted on wingshields.
The windshield can stay for now. I have other things to worry about. I just replaced the passenger side striker and am about to pull the pillar and kick panel.
wildbill
Old Bronco Guy
:p :p :p On the 66/67 broncos you can unbolt them but that is the only 2 years. As I have 2 frames out in the shop now that are 66/67 bolt on.:p :p :p Bill %) :cool: ;D
