sterry
Newbie
Does anyone out there have an tips, tricks, measurements to properly place the windshield cowl panel on the kick panels??
This is all new sheet metal and I've heard to just line up the pre-drilled holes in the cowl / windshield cowl panel to the rear most fender bold holes in the kick panels to place everything properly. But... if I do that, the windshield cowl panel is not square to the rear edge of the kick panels. In other words, the passenger side of the windshield would be ~3/8" further back, when compared to the A-pillars / door, than the drivers side. Obviously that can't be right... But I don't know which side is right, and which side I need to "fix"...
The only reference point I can think of to try to measure the placement is to place a straight edge on the rear most part of the kick panel, run it up, and see where it contacts the windshield cowl panel (if at all). If I do that on the passenger side, I hit the windshield cowl panel about 3/4 of the way up the ~1" lip the windshield rests back against. On the drivers side, I don't hit it at all... Miss it by about 3/16". I don't know which one to consider correct... Or they both could be wrong...
Anyone have any thoughts or measurements you've used to place these things??
Thanks for any help!!
Scott
Scott
