Greg_B
I am going to attempt to remove the wing window frames this afternoon... I have all new rubber and felt coming and the frames are rusty anyway...
I took a peek up inside the door and the spring and nut look pretty rusty. I sprayed them with Fluid Film to let them soak...
I am ging to guess that the nut or the threads will strip off or break... I can make a new pivot pin and new threads... no problem... what about the spring? Is that something that can be sourced locally or is it going to be Bronco specific? It doesnt look special but I figure someone has already been down that road.
Anything else I need to know about removing the frame? Some top secrect method that makes it super easy?
Greg
Greg
