There is a bunch of stuff to reply about here:
4x4man514 said:
im fixing to drop a factory 95 351w with afactory efi harness how will these tw o tie in together?i wont be wasting my time with the first harness will I?
If done corectly, there are only 3 wires that would ever connect the body harenss to the EFI harenss:
Keyed power
Oil PSI gauge
Temp gauge
mlogan24 said:
If you have the money to do it right, ditch that harness and go with this one . . .
Ryan's EFI Harness
Thanks man, just try'n to help out the masses. Here is an old version:
I have sense then included a Inertia cut off plug and a connector for the Baumann Trans controler. Comes "pre-wired" for A/C or OBA
Also 3G ALT plugs are an "Extra" option
unkown said:
Does the factory 351w speed density fit under the hood w/o a body lift?(I have a scoop). I have considered doing this swap...
Umm? Simple answer is no, but I know of a person that has done it. it took a 3" body lift and custom hood that gave an extra 3" of clearance. It's just a big pain in the butt to try in such a small truck.
mlogan24 said:
You can either go with the Franken-hood look, or bite the bullet like I'll be doing soon and go MAF and get the lower profile Mustang-style intake.
Not 100% true. I've built MAF sytems using that big intake, and I've built speed density systems with the newer intake.
Anything is possible, just not always the easiest, best, or cheapest. You pick the combonation I can wire it
![Wink ;) ;)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
