    Discuss it more here:
WTB: Large aftermarket rear tank, 23 gal?
Status
Not open for further replies.
mattt
Looking for an aftermarket rear tank. Dont know if they are all 23gal or what. I need one that is EFI ready. Cash...
SaddleUp
Vancouver, WA
I have a BC Broncos tank that is available. It does not have the EFI pump in the tank but is set up for the return line. (I run it with EFI myself) I need to get enough out of it to replace it with a fuel cell. I am only considering selling it because I would like to push the rearend back a couple of more inches and the tank will be in the way if I do. I need to get about $280 plus shipping for it.
M
mattt
Thanks for the offer. How old is it? Is it banged up? Does it have the skid plate also? I'll have to consider your price vs. a new one for a bit more. Is it the new style with the access cover on top, or the old style EFI tank?
SaddleUp
Vancouver, WA
It's a couple of years old.
It's been awhile since I added a skid plate so I don't recall for sure if it has any dings in it. I don't think so but I need to pull the skid plate off to make sure.
The skid plate would not be included. It is one that I built for it and it is set up specifically to fit my setup. (In the rear it's bolted to my bumper support) It is stainless diamond plate and I used the wrong wire for welding it so the welds failed in the bottom corners and while it is still usefull on mine it would need to be reworked to use for anything else once I take it off. Chances are if I pull it off then I'll cut it up and use it for other projects.
I does not have an access cover. I.E. It is not the tank BC sells for using an internal pump. I bought it shortly before they were available and even if they were I still would have chosen to run the external pump. (I would not risk fouling up a system that had already proven itself) Here is the one I have although when I bought mine it was advertised as a 24 gallon tank rather than a 23 gallon. http://bcbroncos.com/store/product_info.php?products_id=1186 I'm not sure if they changed the tank since then or if it just doesn't have as much capacity as he originally claimed.
Status
