    Discuss it more here:
CA WTB: transfer case mount/cross member bushings, Aftermarket BCB PB Booster Grommet
Status
Not open for further replies.
mattt
Looking for a few things....
A set of urethane or rubber bushings for the crossmember/trans adapter mount...preferrably ones with a taper at the top.
A PB Booster grommet for the check valve. I have a BC booster and I can't find this exact grommet at any local parts store, it is different from the commonly available booster grommet. It uses a 3/4" check valve.
M
mattt
Found the D20 idler shaft. Still looking for the other stuff.
thegreatjustino
Red Head Grease Monkey
Stockton, CA
If this helps you any, a 70's econoline van in the junk yard will have the correct grommet for the vacuum booster. This is how I found mine.
73stallion
Eugene, OR
yep, it's RW. he's full of hot air, which is why i don't work for him anymore. a few people i associate with feel the same.
Status
