Bronc076
I am in the process of installing a ZF 5 speed in my 76 Bronco Sport, J shift Dana 20. In addition to the BC Crossmember, and AA install kit I have a JB Custom Fab twin stick.
For some reason my AA kit does not have the drill mark for top. When I had the transmission on the floor I checked numerous times and verified the clocking ring only fit the transmission one way. I used the center threaded holes (AA clocking ring has three choices) and put it all together. My shifter did not fit. I contacted JB Custom Fab (awesome customer service from the owner) and sent him some pics. He pointed out the shift rails were at an angle. He told me it looked like I had the case too high. So, I used the next set of holes and rotated the case down some, the shifter fit perfectly.
Last night I put the engine (91 Thunderbird 5.0) and transmission in the truck. Today I put the Transfer case and twin stick in, all seemed to be going well. Then I go to put the front drive shaft on and the CV joint hits the cross member, there is not enough room to put the front shaft on. I put a ½ inch bushing between the transmission and the crossmember and it still does not fit.
So, now I’m thinking I have a clocking issue with the AA kit.
I pulled it back out, took the clocking ring off the transfer case and screwed some studs into it and crawled back under the truck. It only fits the ZF one way.
So, anyone else using these same parts? I would think the BC cross member and AA kit would work together, do I need to buy the BC shifter, or should the JB Custom fab shifter work?
I’m not digging on either business, I have done a lbusiness with BC over the years, and JB has done more than enough to make me happy. Both places are great to deal with.
I’m thinking either I did something wrong, or the AA ring is defective, and there is some happy medium where the case will be clocked up slightly, and the drive shaft will fit, and the twin stick should still work. The fact that my AA clocking ring does not have top labeled like ones I have seen on here do bothers me. Also the shifter bracket I got with the AA kit looks like some high school kid welded it together. Perhaps I need a new bracket, and to use the center hole on the clocking ring.
Any advice? I’m going to call BC tomorrow and see what they have to say, hopefully they can point me in the right direction.
