Hey guys , after about six years I'm finally starting to get my burned up bronco back together. When they blasted my frame I had them blast the tranny too. Today I started looking over it better and I took the top shifter cover off and found some grit in there. I had it wrapped pretty good but I guess high pressure sand has a way of finding its way in. Upon looking a little deeper I seen some surface rust on the gears as we'll. It didn't look bad but there again I could only see in there a little bit.
My question is is there a good way to flush this thing out without taking the tranny apart? An should I worry much about the rust? Or should I take it somewhere? And how much is the going price for going thru one of these? I went all through the old bronco tranny so I know a little bit but I imagine this will be a lot more involved. And my transfer case is still attached so I was hoping to avoid some of the extra work with my bad back.
Thanks for the input guys!
