ZF5 transmission Tunnel measurements to hole Opening
Does anyone have measurements from the front edge of the transmission tunnel cover before it slopes up upward to the center of the hole opening for a ZF5 in the early Bronco? thank you for any help
cwarren87
I don't have the measurements off the top of my head, but if you follow the link to an old post I made there are some good pictures of the hole I cut for the ZF5 along with the measurements of the hole. If that doesn't help I can pull the boot and measure for you when I get home from work on friday.
https://classicbroncos.com/forums/threads/zf-5-shifter-boot.171399/#post-1670767
Big Slim
Mine has a 2” BL. I had to cut about 1/2” up on angled piece.
phred
Earth
Yeah the zf is a big rascal. Body lift for sure unless you want to cut the tunnel out and fabricate a new one.
