Third times a charm v3.0
JSmall
JSmall
^ I think that's where the few degrees of difference comes in. Under heavy load your drive shaft and pinion angle will be a close match, but under light load you have just a few degrees of separation.
I thought it would be 2-4* under. I guess I should rebuild my DS and test it out before I cut off my old leaf mounts.
JSmall
JSmall
I have a few things to install this weekend. I'll get the fuse box in this weekend and hopefully have enough time get the spring perches in. The billet dash knobs will have to wait until my dash is done.
Rough Stuff makes a great product. I have their full width swap kit and a few steering parts to add when I swap axles. Until then, these will have to work to correct my pinion angle.
JSmall
JSmall
Made a little progress on the wiring. Everything will be in an aluminum box with a lid when I'm finished. I'll be installing a light in there as well
JSmall
JSmall
Wiring and custom enclosure has been finished.
Under the hood is looking much better. Still need to figure out what I want to do with the heater hoses and clean a few more things up.
JSmall
JSmall
Bringing the build thread current.
New 33x10.5 KM2s w/ stock wheels and caps
Dash should be going in soon so I'll be able to put my roll bar back in. I also removed the hideous front bumper setup and installed a stock bumper that came with it. Not in the best shape, but it will do for now.
sprdv1
REBEL
Woohooo lovin that ride man.. custom work looks good under thehood. ;)
JSmall
JSmall
Got the dash back from a friend and it did not like how the finish worked turned out. I dropped it off at a local custom shop to be reworked. I should have it back soon.
Old dash
Before I took it in the second time
Big difference, but it wasn't perfect
JSmall
JSmall
Thanks. It is about to look much better with the addition of hydro boost and R&M Specialties billet wire loom for the plug wires. The old vacuum boost setup needs to go and I'm not a fan of the current plup wire routing. Should look good soon.
JSmall
JSmall
Great looking ride. I used to live in Tualatin. Over on 103 ave.
I live off Martinazzi right now. There are a few other Bronco brothers within a mile from my place.
BR549
huntsville
did not see if you have any lift on her. how wide are stock wheels. isnt that wheel below recommended with for a 10.5 tire. just asking/ trying to learn.
JSmall
JSmall
I have a 2" lift right now. The wheels are 15x6 and I didn't have an issues having them installed. It would be like putting a 12.5" tire on a 8" wheel. I don't see it being an issue. Only time will tell.
Crawdad
My tire guy wouldn't give me a warranty with 10.5"s on a stock 5.5" EB rim. Said I needed a 15x7 for my 33x10.5" KM2s. I could not find any stock 15x7s but he honored the warranty on stock 15x6s. I love my skinny 33s, can't wait to change tubs and go UNCUT!!!!!!!!!
JSmall
JSmall
My tire guy wouldn't give me a warrantee with 10.5"s on a stock 5.5" EB rim. Said I needed a 15x7 for my 33x10.5" KM2s. I could not find any stock 15x7s but he honored the warrantee on stock 15x6s. I love my skinny 33s, can't wait to change tubs and go UNCUT!!!!!!!!!
I purchased the warranty through America's Tire and they did not have an issue with the 15x6 wheel.
JSmall
JSmall
Sitting in the Atlanta airport bored out of mind so I'm going to post crappy pics of my finished dash project.
-refurbished cluster w/ LEDS
-LED dash lights
-billet knobs
-Tom's steering wheel
-glove box moved over a few inches
-ash tray and a few other holes filled in
