New hub doesnt fit!?
Broncrick
Nevada City,CA
Pulled the old Warns to pack bearings and install the sweet stainless Mile Marker hubs. Pass side went A-Ok, driver side internals wont seat in all the way so I can get the big snap ring in :p Filed all the grooves to make sure it wasnt binding there, doesnt seem to be bottoming out on the spindle, wtf? and yes the old Warn internals still fit....
Anyone else run across this? Want to run Fordyce this weekend ;D
I know you said the big snapring, but just so I'm sure, you are talking about the main retaining ring that goes into the groove in the outer hub, right? Not the snapring that fits on the axle shaft end?
Just checking because it's common for the axle snapring to not fit with aftermarket hubs. But haven't seen one that wouldn't go in far enough to seat the big one. Hmmm, did you try rotating it into different splines? I know they're all supposed to be the same, but just in case there's a burr meeting a burr, or something like that, might help to rotate it to a new position.
And another double-check, you don't still have those big stock springs in behind the locking hubs to do you? Sounds like you've done this before so you probably already know about that. And the Warns were already there... But I figured I'd check.
Hope you got it fixed already.
brian72
Early Bronco Student
I had the same exact problem. I sent the set back to MM and they sent me a NEW set...they fit.
U
Unregistered
Guest
Same thing on mine, I swapped sides and they worked.
I found that the mile markers only work with there snaprings, not the warn snaprings.
Hint: file a little taper on the end of the snapring so you can get a screwdriver under it to lift it out later. If not, it gets to be a real bear to get them out.
B
Broncrick
Nevada City,CA
Donk, yep big retainer ring. Tried to rotate the assy, filed all questionable 'burrs' inside, used both rings, dunno %) will try to swap sides and hope that works, otherwise I'll ship them back I guess...
Good hnit Broncobowsher, but I use a 90* dental pic I got from my Dentist :cool:
