Dusty
- Jun 28, 2001
- 2,965
Many of you are familiar with the cool billet aluminum roll bar accessories such as grab bars, hi-lift jack mounts, flashlight and fire extinguisher holders, etc made by FourTreks. Luke, the owner of FourTreks, is a good friend of ours here at West Coast Broncos and a fellow Early Bronco fanatic. We've recently added their products to our website, but we're now offering a nice discount on them to coincide with announcing another cool new product from FourTreks.
Luke just released the Modular Horizontal Tab Mount, a versatile mounting system for all sorts of items such as antennas, auxiliary lights, or even roof racks when using several at a time.
Looking for a place to mount your whip antenna, cb antenna, flood light or driving light? Use our Horizontal Mount Tab to mount it on your roll cage, roof rack or bumper. Designed to work on a horizontal tube of your choice. This mount includes our standard billet aluminum Clamp Ring, a stainless steel threaded Horizontal Tab and all the necessary stainless steel hardware. The Tab can be ordered with two different through hole diameters. One option will accept standard 1/2" SO-239 antenna mount stud used with CB antennas, standard CB coax cables and ham radio antennas. The other option can be used to mount various spot or flood lites and whip antennas to your vehicle's tubing. Choose your application from the pull down menus. CB antenna, second mount and flood light shown not included. Stainless steel hardware is included. Available for a wide range of tubing diameter applications. See the pull down menu for our extensive sizing options.
All FourTreks modular mounting components are precision-machined from T-6061 aluminum for light weight yet high strength. The system is made up of two basic components; a clamp ring and an adapter. The clamp ring is precisely machined to clamp around your exact roll bar diameterr: 1", 1-1/8", 1-1/4", 1-1/2”, 1-5/8”, 1-3/4”, 1-7/8”, 2” and 2-1/4”. The two-piece clamp ring bolts around your roll bar using stainless steel hardware. The second component is the adapter (to mount the ji-lift jack, shovel, flashlight, etc). Because the system is modular, all components can be interchanged, making it easy to switch between different tubing sizes without having to buy a new complete kit.
We'll be sponsoring a Give-Away of one of these horizontal tab mounts in a couple of weeks, so post up in that thread to enter. And be sure to pick up all of the FourTreks products you need for your rig before the special pricing ends! Go to our page with all of the FourTreks roll cage accessories to place your order.
Dusty
