I will only deliver to the MEB round up or All Ford in Carlisle
Parts must be paid for to get them loaded.
make a reasonable offer or wait a few days and I will put some prices on them.
If you want pics I can send them.
Seats Stock Bronco, needs covers $40
Seats From a Toyota I think, black has 1/4" flat bar on the bottom welded to the seat track, was mounted in an F-250. $40
Mr. Gasket aluminum carb adapter, 4bdl manifold - 2bdl carb
Points distributor
Stock Bronco carb, clean, but was leaking from the power valve or accel pump.
Another Stock carb used looking
Chrome motor sports valve covers one is dented in the back corner $10
Holly Dominator 302 manifold $25
3.5" Super lift front & rear springs ( rear needs bushings) $50
Astro Hydro boost, proportioning valve & MC $50
Grant FORMULA GT mahogany steering wheel Grant 714
B&M Mega Shifter
Stock Bronco voltage regulator (s), I have a few they were my trail spares I have both types.
Stock fan shroud from a 69 Bronco
Drop pitman arm sold
Flex plat C-4 $10
"Check disc Brake spindles & backing plates $50 ( one spindle is pitted and the backing plates are fair condition)
C-4 Kick down rod
J-shifter
Dura spark distributor module (s) blue grommet ( my old trail spares)
Stock Bronco Alternator (s)
C-4 torque converter (s) used
Hard tops (3) ( I have the good, bad & ugly)
Aux tank NWM aftermarket steel 11 gallons I think, includes straps, filler neck
9" rear axle 4:11 Brake -Brake Detroit locker 28 spline
Oil Pan stock bronco screw in dipstick included
stock Smog pump Bracket
stock Power steering bracket with pump
stock Alternator bracket
351 alternator bracket adapter
84 Chevy Suburban diesel Hydro boost & MC $50
Points distributor
B&M Mega Shifter
Flex plat C-4 $10
C-4 Kick down rod
J-shifter
